51 Plymouth electrical / lighting / turn signal / rewiring front to rear
Started by bluestreak[delete this bit 6a7e5944746b3][insert an at symbol here]citlink[insert a dot here]net, May 04, 2025, 09:12:50 PM
If you are adding turn signals to a car that did not come from the factory with turn signals, remember that you have to remove the front parking light sockets and replace them with dual filament sockets and bulbs.
SteveR
Sometimes Chickens Sometimes Feathers
Paul McD
The last couple of pages of the service manual have detailed wiring diagrams.
Hope this helps
bluestreak[delete this bit 6a7e594474571][insert an at symbol here]citlink[insert a dot here]net
My issue is that I cant get info on how to wire the car to make the blinkers brake lights to work properly.
Does anyone have a clearly defined wiring schematic?
Thank You very much!
