Gas Tank-Replacement/sealer-?
Started by DENNIS P NOLAN, April 29, 2021, 12:56:51 PM
crazyred
Dennis, on my 33 plymouth i had a very rusty tank. I tried to clean the tank but never washed it all out. I ended up buying a new tank made by tanks inc. I found it through summit racing with free shipping. It's great quality. I had a filler neck made instead of using the one sent. I would check out there site to see if they offer one for your 39.
Good luck!
twpoulter
Hi Dennis think you need to look at this stuff POR15 High Performance Fuel Tank Sealer 236ml 8oz - Stops and Seals Rust, Corrosion and Pin-Holes, in the UK that would cost £20+ shipping. I'm pretty sure it's made in the States. Hope it helps. Tom
   [attachment id=0 msg=20284]
  https://ctrestorations.com/
DENNIS P NOLAN
Hi- have a 1939 P-8
I took the tank in to be cleaned out- and it has many holes.
The technician-says the metal is very thin in many areas.
So, is it possible to get a sealer that might work?
Anyone with experience in this area?
Next question-
Anyone have thoughts on where to get a good replacement?
I see google has some listings from the East coast for $395.00 + Shipping-
Thanks,
Dennis
