Author Topic: Positive ground strap  (Read 115 times)
  • Full throttle user!
Re: Positive ground strap
« Reply #7 on: August 17, 2020, 08:43:38 PM »
As a factory photo shows , it does go to the head bolt. Car starts fine. 6V
Ernie Baily
  • First Gear
« Reply #6 on: August 15, 2020, 01:27:50 PM »
My ground goes to the generator mount bolt on my 48 Ply, I then put a second cable from the generator mount to one of the starter bolts.
« Reply #5 on: August 14, 2020, 10:01:27 PM »
Let's see the rest of your new car!
32cabrio
« Reply #4 on: August 14, 2020, 10:17:05 AM »
If your ground strap is a braided one, and has been on there for a
long time you would be better off replacing it. They tend to corrode
over time and set up a resistance which will degrade the performance
of you electrical system.
« Reply #3 on: August 14, 2020, 06:06:30 AM »
Thanks for the reply. That is a nice picture showing the cable to the engine. Will take it off and clean and put it back. Just bought this car. 38,000 original miles. Bought from 2nd owner who bought it in 1960
« Reply #2 on: August 14, 2020, 03:13:28 AM »
never did I see other, so Ibelieve it to be the original setup:
The GND strap goes from battery to the headbolt.
Here is the only proof I fond (Service Manual P15 - P24),
and one Foto off POC Forum, but here a cable instead of a woven strap.
Bill´s GND goes to the front of the block, mine was to the middle of the block.
 [ You are not allowed to view attachments ]
« Last Edit: August 14, 2020, 03:15:20 AM by Go Fleiter »
« Reply #1 on: August 13, 2020, 05:00:35 PM »
On the 1949 P-18, is the positive ground cable mounted on a head bolt. Should it go to frame ground.
