Author Topic: ## PD Carb Needle Valve  (Read 208 times)
  • Full throttle user!
Re: ## PD Carb Needle Valve
« Reply #4 on: June 22, 2020, 11:12:30 PM »
33inCanada,
Have you looked at www.carbkitsource.com  ?  Go there, look up your model number and see a photo of the carb kit they sell for it.
It appears they sell a kit for a BBR-1.  The photo looks like it comes with a needle and seat.
-Bill Davis, Florence,AL
33incanada
  • Proven posts ok.
« Reply #3 on: May 30, 2020, 04:34:41 PM »
Thanks Todd   You are right as usual!     Discovered the 439s was a factory replacement carb for 33-38 Plymouths. Now have to find a needle valve reference. Someone suggested may have been standard on the 39. Thanks for your help.......Cheers from B.C.!
  • 1933 PD Two Door Sedan
    • Plymouth: The First Decade
« Reply #2 on: May 30, 2020, 12:24:33 PM »
Need a needle Valve and seat for my Carter BBR-1 in my 1933 Plymouth Sedan.  The one that came in the Carb kit was crap.  The listings I see for needle valves dont show BBR-1  but list Part 3 NS509 for  Carter BBS, BBD and BBR 154???
Is BBR 154 same as BBR-1???
That is not an original '33 Plymouth carburetor. The 439S number stamped into the web should identify the carburetor kit that is needed.But I don't see that number in my limited number of Plymouth books.
33incanada
  • Proven posts ok.
« Reply #1 on: May 29, 2020, 08:41:27 PM »
