Author Topic: 1933-34 2 door sedan body mounts  (Read 803 times)
  • Full throttle user!
  • 1933 PD Two Door Sedan
    • Plymouth: The First Decade
Re: 1933-34 2 door sedan body mounts
« Reply #4 on: November 19, 2019, 01:15:13 PM »
that is what i am looking for is the wood that goes between the frame and the body.
I didn't make drawings or patterns from mine. I think your best bet will be finding someone who has the body off the frame for restoration. You may want to place an ad in the Plymouth Bulletin.
frank k
  • First Gear
« Reply #3 on: November 19, 2019, 02:32:01 AM »
« Reply #2 on: November 12, 2019, 06:17:24 PM »
I'd have did out my old disassembly photos, but I don't recall any body mounts per se on my '33 Plymouth two door sedan. As I recall there was canvas between a long piece of hardwood and the frame and the body rested on the hardwood with through bolts hold the body and wood rails to the frame.
frank k
  • First Gear
« Reply #1 on: November 12, 2019, 05:44:40 PM »
I am looking for a set of original body mounts for the 33-34 2 door sedan. These do not need to be new just good enough i can use for a pattern 1 time.  I think these should be the same as the dodge of the same years. thanks in advance for any help. frank
