1932 Plymouth PB battery cable routing.
Started by GeraldT, June 13, 2017, 10:48:50 PM
Jerry
I have a PB Sports Roadster and routed the Negative cable along the left side of the clutch pedal and up to the starter.  Did that 3 years ago and no rubbing or other problems
GeraldT
I cannot figure out the route of the negative
battery cable to starter on my recently acquired '32 Plymouth PB.. I would appreciate if someone who knows or can look at theirs to tell me the routing,left or right of the column or brake pedal.Just seems to be a lot of things that could rub against it. The previous owner had two 24" cables bolted together at the bare terminals. I had a supposedly correct one put  together by John Brillman and it is shielded but I still do not know where it enters engine compartment.Thank You Gerald Tobin 1718 Baltimore Road Lancaster Ohio 43130. email
