Alignment
Started by pondcarp, April 25, 2006, 09:39:36 PM
pondcarp
My 52 Cranboork was badly out of alignment since the tension bar ? was broken and I had it welded.  I found a shop that does this the old way, not just with electronics.  He said that he did not have the specs, I told him I had a manual and the specs.  He cleaned enough dirt,grease, etc. off the parts to work on it.  He was able to get every thing back into spec and said that all the parts seem to be in good condition.  Normal Front alignment costs $70.00 & that was his charge.  That was great and when all four wheels are pointed the same direction it drives much better.
If you have this type of problem I probably look up the specs from 46-52 for you.
Ron
Ron "pondcarp" Holloway
